question
Sajidh Z. avatar image
Sajidh Z. asked ·
deploying dynatrace to azure cloud
Hi , we are currently using https://community.dynatrace.com/community/pages/viewpage.action?title=How+to+deploy+Dynatrace+Agents+in+MS+Azure+Cloud-Service&spaceKey=LEARN
this method to push dynatrace agent to the azure cloud, Agent starts and runs fine , but seems like Agent doesnt gets installed as a software ( doesnt appear in programs and features) , double clicking the dtagentconf opens the usual dynatrace GUI . this is the folder structure which gets
created in the VM after the cloud deployment
note : "manualy double clicking the dynatrace-agent.msi which is inside the folder that gets created installs dynatrace agent as a Software in the computer "
so I have got a question , is it a normal behaviour ( running dtagent as a service without installing dynatrace agent in the windows programs ) ? , or am I missing something
appmon6.5agent
Andreas G. avatar image
Andreas G. answered ·
Hi
For AppMon this is normal behavior. The Agent itself IS NOT a windows service. The Agent is simply a DLL that will get loaded into your .NET processes
Besides our support for Azure with Dynatrace AppMon & UEM I also want to point out our new capabilities for Azure with our Dynatrace SaaS / Managed offering that already uses our new Dynatrace OneAgent technology. I recently recorded a youtube tutorial with our MS Technology Lead where he talks about which use cases we support: https://www.youtube.com/watch?v=QFRUiPiCuHw&list=P...
Andi
5 comments Share
Hi ,
Thanks for the support , I wanted to try out the new dynatrace OneAgent Extenstion by adding it to our Azure portal, unfortunately I cant add the extension because we are using Azure as a Cloud service , is there any work around for this ?
many thanks
Sajidh
1 Like 1 · ·
Hi Sadjih, whether you're using AppMon or Dynatrace SaaS - Azure Site-Extensions are only applicable to Azure App-Services and not Azure Cloud-Services. If your're going to proceed with AppMon on Azure Cloud-Services, please stick with the tutorial in your initial post. If your're trying to use Dynatrace SaaS on Cloud-Services please follow Martin's tutorial posted a few minutes back.
Patrick
2 Likes 2 · ·
For monitoring Azure CloudServices with OneAgent in particular, please follow the guidelines here: https://github.com/dynatrace-innovationlab/azure-cloud-services
Hope that helps, let me know if you have any trouble
Martin
2 Likes 2 · ·
Hi Martin ,
We are trying to use dynatrace managed on azure cloud services and i could see the site extension cannot be used and we can install the one agents via start-up scripts.
The link that you have given seems to be broken & i could see only the scripts for App mon agent installation.
Could you help us on how to process with the one agent installation for cloud services ?
Thanks & Regards ,
Suganya
1 Like 1 · ·
You can find latest guide on https://github.com/dtPaTh/Dynatrace-Azure-CloudServices
Best
Patrick
0 Likes 0 · ·
Patrick T. avatar image
Patrick T. answered ·
Hi Sadjih,
you're basically right with your investigation. In a typical scenario, manually installing the agents using the MSI, they appear as any other software and can be also uninstalled that way. For azure cloud-services, the MSI is used as an archive and just extracted. within the automation powershell scripts. This is the reason why you don't see it within the installed software list.
Patrick
Share
