question
David D. avatar image
David D. asked ·
Support for Apache ActiveMQ
As there will be movement in our company away from WMB brokers and movement to use Apache ActiveMQ in its place can someone please tell me if Dynatrace appmon supports ActiveMQ, to what extent, in what version and where I could find more information on this?
David
messagebroker
David D. answered ·
Thanks Harry, I appreciate yours and Ingo's input! It is definitely a tough question no doubt. But still you guys gave me great info!
David
Share
Afroz H. avatar image
Afroz H. answered ·
I want to automate installation and configuration of dynatrace agent for activemq monitoring.
Could you please let me know steps do the same.
Afroz
Share
Harald B. avatar image
Harald B. answered ·
Hi David,
This is difficult to answer. Both servers are not comparable and it also highly depends on the used API (JMS with ActiveMQ?). PurePaths and visibility will be different.
Best
Harry
Share
David D. answered ·
Thanks Harry and Ingo! Appreciate it! I was asked by the MQ team if it did support it. However, the real question is beyond what they are asking is does it give the visibility that the WMB broker agents give. If their decision to move their infrastructure to ActiveMQ from WMB is partially based on not losing visibility its going to be important for me to understand the difference. It is sounding like it is not as fully supported as WMB and there will be a lot of visibility missing that the company is used to with the wmb broker agents. Is that a safe statement to make?
David
Share
Hi David,
Please note that AppMon instruments the JMS producer / consumer API. So the JMS server itself has not to be instrumented. But as Ingo already stated: it is supported.
Best
Harry
Share
Ingo H. avatar image
Ingo H. answered ·
Share
