• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Simon S. · Mar 15, 2017 at 04:16 PM · 6.5 web performance monitoring production iis
Timeouts - Async Path (threading)
We've started noticing that more and more of our requests are getting timeouts, I've begun digging into this but the only thing I've able to see is, in the purepath tree (on one of those requests) there was a sudden jump (of 30 sec) between async invocation and async path (threading). Further down in the tree our log4net reports that the timeout expired.
Might be completely off with my "finding" but if anyone has any ideas of where to look I'd greatly appreciate it!
Comment
People who like this
0 Show 0
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Mar 24, 2017 at 06:00 AM
Hey Simon
I've seen this situation many times in the past. This typically indicates that your system is running low on worker threads. The PurePath you posted is trying to schedule a job that gets executed on a background thread. It takes 30s until the next thread becomes available. Now - 30s is a very "suspicous" time for me. I "assume" that the real problem is in some of your background thread processing where these threads are doing some work or waiting on something for up to 30s. After 30s they probably hit some type of timeout and then "finish/abort" their job. this means that the thread becomes available again which means they can pick up work from e.g: the PurePath you showed.
I would look into other PurePaths that show activity in these background threads. Try to figure out if they do some heavy processing, connect to external systems (or DB) and whether they run into any timeouts. I good way to start is by looking at the Exception Dashlet and try to find any "Timeout" exceptions. then drill to the PurePaths from there. Another option is to open the method hotspots dashlet -> this should show you if you have methods that wait a long time for a response from an external system
hope this helps
andi
Comment
Simon S.
1 Show 1 · Share
â–¼
avatar image Simon S. · Mar 24, 2017 at 06:53 AM 0
Share
Thanks Andi!
That's actually really helpful, I'll start looking right away!
Simon
Join the conversation!
First steps in the forum
Community User Guide
LIVE WEBINAR
"Power Demo: Software Intelligence for Cloud Infrastructure"
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Register here
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
22 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Java Script agent is not loaded and getting 404 on http://server:port/dynaTraceMonitor 4 Answers
User Actions Not coming in a correct system profile 1 Answer
Performance overhead of enabling bind value capturing and increase the SQL capture length 4 Answers
How to report performance for specific users set 1 Answer
Disconnected transaction flow 1 Answer
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api errors dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java browser agent community user guide hybris javascript appmon sensors good to know search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow diagnostics user session monitoring unique users continuous delivery configuration alerting NGINX splitting business transaction client 6.3 installation chart database scheduler apache mobileapp RUM php dashlet azure purepath plugins agent 7.1 appmonsaas messagebroker nodejs 6.2 incidents android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
