question
Rejith R. avatar image
Rejith R. asked ·
Simple Host monitoring question
I have 5 servers under an agent group. I need to create an Incident only for one of the servers in the group , for a high CPU condition. I am not worried about the other 4 at all. How to do that ? Looks a simple scenario, but somehow I am missing something
hybris
Darren M. avatar image
Darren M. answered ·
You can specify separate Host thresholds under the main Settings section. In there is 'Infrastructure' settings. This is where all Hosts are listed regardless of system profile. By default all Hosts have thresholds set against the Default HostGroup.
Un-tick the 'Use Thresholds of the Selected HostGroup....' and then you'll be able to specify thresholds just for that particular Host.
Regards
DM
Share
Rejith R. answered ·
Thanks @James K. But we are using the ServiceNow plug-in
Share
James K. avatar image
James K. answered ·
If you would like to continue using custom incident rules and only alerting on a specific host consider using the extended email action plugin instead of the out of the box email action. This one allows you to do a lot more filtering on the emails and you can specify which host you want to receive the alert on.
https://community.dynatrace.com/community/display/...
James
Share
@Darren M. So your advise is to have manual thresholds for the servers of interest and get that monitored by default incident rule "Host CPU Unhealthy" ??? Our plan was to disable all these defult Incident rules !!
Share
Babar Q. avatar image
Babar Q. answered ·
Hello Rejith,
I guess this is not possible under the 'Host Performance' measure because it is for the system profile / all agent groups.
If we take the 'Server Side Performance' measure then we can select the specific 'Agent Group' but even though it will not be the same you are looking for.
Babar
Share
