question
Wai C. avatar image
Wai C. asked ·
Is BizFuse ASP Tomcat supported by dynaTrace AppMon?
appmon6.5agent
1 Answer
Andreas G. avatar image
Andreas G. answered ·
Hi Wai
I am not familiar with BizFuse ASP. I tried to search for it but couldnt find more information about it. What I can tell you is that Dynatrace supports any Java Application Server - which also includes Tomcat. If BizFuse is a framework that you host in Tomcat than chances are very high that it is supported
Andi
Share
