question
See V. avatar image
See V. asked ·
OCSG Diameter Communications Monitoring
Hi all,
I'm currently working on setting up a custom sensor to monitor outbound communications from OCSG to Huawei backend services using the Diameter protocol. The team here uses the px30 Diameter payment plugin to handle the communications.
I'm wondering if anyone of you can point out to me on which method it is that handles the outbound communication this way? I've been looking into the tree "com.bea.wlcp.wlng.px30.plugin..." in the class browser, but nothing there seemed to work yet.
business transactionsensor6.2
1 comment
I wonder if you were lucky with this. I have the same need
0 Likes 0 · ·
1 Answer
Joe H. avatar image
Joe H. answered ·
I would suggest you use the CPU sampler to inspect what's going on in the JVM on that thread. That will provide you a full call stack where a likely sensor point can be identified.
1 comment Share
You can use the 'External API Service call' to show this on the transaction flow. Here I've done this for a Kafka to illustrate the time spent writing to each kafka topic.
1 Like 1 · ·
