question
Avin B. avatar image
Avin B. asked ·
problems restarting 6.2 host agents services on windows servers"severe [native] Exception in controller: receiveExact() ... not connected, 730053, Software caused connection abort. Retrying every 10 seconds.
agentcollector6.2
David D. avatar image
David D. answered ·
We had the same issue (version 7.1) and a restart corrected it.
Share
Kishan A. avatar image
Kishan A. answered ·
Hi Babar,
Please see attached agent log with error as requested.
Kishandt-os-12360.log
dt-os-12360.log (24.8 KiB)
1 comment Share
Hello Kishan,
Did you restart your collector after this issue? if NOT
Can you restart easily to check the result?
Babar
0 Likes 0 · ·
Avin B. answered ·
Hi Babar,
We saw this message in the host agent log file for a few host agents.
Andre
1 comment Share
Hello Andre,
Can you share the host agents log file here?
Babar
0 Likes 0 · ·
Babar Q. avatar image
Babar Q. answered ·
Hello Avin,
In which log file did you see this message?
Can you share some more informaiton?
Babar
2 comments Share
Hi Babar,
Please see support call logged for problem...
  1. SUPDT-33684
Kishan
0 Likes 0 · ·
Hello Kishan,
I cannot access the support case due to my limited account rights.
Babar
0 Likes 0 · ·
