question
Sun K. avatar image
Sun K. asked ·
Is there F5 Load Balancer plugin available? The similar as AppD already supports.
as per subject, I am interested in F5 plugin that can retrieve performance metrics from the F5 over REST API.
An example of AppDynamics implementation:
https://www.appdynamics.com/community/exchange/extension/f5-monitoring-extension/
pluginsweb performance monitoringproduction
Mike L. avatar image
Mike L. answered ·
Share
Jakub M. avatar image
Jakub M. answered ·
F5 EAP will be started in June. I order to join EAP pleas contact with @Michael L.
4 comments Share
Thank you. I really appreciate it.
0 Likes 0 · ·
Hi Sun,
The F5 platform extension for Dynatrace is currently in early access.
Here is the link to the Platform Extensions homepage:
https://www.dynatrace.com/services-support/platfor...
And fact sheet:
https://assets.dynatrace.com/en/docs/fs/2782-platf...
Andrew
0 Likes 0 · ·
Hello - I'm a little confused about this, the document states "Dynatrace Extensions are ready-made, easy to deploy, and fully supported components" - but where do we obtain the F5 or Datapower extensions?
0 Likes 0 · ·
Hi Ben,
I suggest you to send through a contact request https://www.dynatrace.com/contact/ and select "I want to be contacted by services". Ask to be placed into the Early Access Program (EAP) for Dynatrace Extension Services.
Andrew
0 Likes 0 · ·
Chase H. avatar image
Chase H. answered ·
It looks like @Michael L. knows about the EAP for Dynatrace (not AppMon). There's also a way to publish the information via API if you're already collecting the data (I think they assume a lot though).
Share
Apparao B. avatar image
Apparao B. answered ·
We are also having a need to monitor our F5s. Appreciate if you can share the status and installation details for this plugin. Thanks !
Share
Michael P. avatar image
Michael P. answered ·
I am also looking into this plugin. Is there an EAP? Thank you.
Share
Larry R. avatar image
Larry R. answered ·
What is the status on this? Is this feature now available for Dynatrace? Thanks!
Share
Mohaideen S. avatar image
Mohaideen S. answered ·
I am also looking this plug in. Can you please provide information here. Thanks in advance.
Share
Adam G. avatar image
Adam G. answered ·
@Dave M. Can you help here?
1 comment Share
Hi Adam,
A while ago I looked at the REST option, like AppD, but decided to try the SNMP option instead in order to leverage the already existing SNMP plugin. I found it works to turn a MIB into a metric group, but only for the "static" values (not tables). I then looked into using SNMPWalk to get all exposed numeric metrics and found it was hard to turn the numeric OIDs into text OIDs. Then other work took over and I left it all behind. Also, I believe @Asad A. was looking into creating a REST-based version of the plugin fairly recently.
dave
0 Likes 0 · ·
Slawek M. avatar image
Slawek M. answered ·
@Alex: Long time no hear from you :-)
To answer your question - I've made such plugin to monitor BIG-IP. In my case, I'm using native F5 interface, the way F5 admin console does.
It' faster, more stable, less complex than REST.
IMO - better data quality, when compared to AppD, i.e. I'm reporting per individual F5 CPU...
Contact me: slawomir.michalik@omnilogy.pl if you need to know more details.
Cheers,
Slawek
Share
Jakub M. answered ·
Hello Alex,
We are currently working for built-in F5 remote plugin for Dynatrace (it will not be available in AppMon)
What performance metrics are most important for you?
Best,
Jakub
Share
