question
Babar Q. avatar image
Babar Q. asked ·
x-dtReferer Security Block
Dear All,
We have a situation that one of the iOS instrumented application has a long x-dtRefere in the POST data and security (WAF) is blocking due to this especially /var/.
How we can avoid this?
Babar
6.5uemjavascriptsecuritymobile monitoringadkios
1 comment
@Babar Q. This is very old post, however, just want to check. Did you find resolution for this issue. I am getting same issue.
0 Likes 0 · ·
Babar Q. answered ·
Hello James,
Thank you for your answer.
Since very long I am telling security to high your level instead of blocking everything but time to time they are give us a tough time like the same I posted here.
Let me ask support, if they can help in this situation.
Babar
Share
James K. avatar image
James K. answered ·
I doubt there's way to decrease the size of that while maintaining functionality, maybe support has some options but really my first step would be to work with the team in charge of the WAF and see if they can recognize this traffic as legitimate and let it through.
James
Share
