question
Bill S. avatar image
Bill S. asked ·
MQ Broker Agent name is not correct
dynatrace-agent-mq-broker-configuration.pptxI noticed after upgrading the agent bootstrap for MQ Broker that the environment variable for DT_AGENTNAME is not the same as what is presented when the agent starts. According to the documentation, if this environment variable isn't set, then WebSphere_MQ is set as the default. Well, the variable is set (as shown in the attached document)! Is this something that changed when I upgraded the agent bootstrap? Will this result be the same in version 7?
6.5messagebroker
Christian S. avatar image
Christian S. answered ·
hi Bill,
as of your powerpoint, you did not export the DT_AGENTNAME variable, so it's only available in the current shell process and none of the subprocesses (like, e.g. the WSMB/IIB processes).
please try to export the variable and let us know if that helped.
HTH, Christian
Share
Bill S. answered ·
Thanks. :) I was either going to do that or post here.
Bill
Share
Bill S. answered ·
I understand. I wanted the versions to be the same.
In the attached document from my original posting, the screenshots are AFTER the installation, and AFTER I configured dtwsmbagent with the correct settings. After all the configurations were complete, I restarted broker.
I executed the commands for to instrument on specific execution groups.
mqsichangebroker <broker> [-x <path to libdtagent.lel>]
mqsichangeflowuserexits <broker> -e <ExecutionGroup> -a dtwsmbagent"
1 comment Share
Your taken steps are correct. I guess you should open a support case to understand this behavior.
0 Likes 0 · ·
Babar Q. avatar image
Babar Q. answered ·
Hello Bill,
Basically bootstrap version of 6.2 & 6.3 are compatible with the 6.5 agents and there was no need to upgrade the bootstrap agents.
Now you installed a new agent, therefore, it took the default settings of DT_AGENTNAME, so you will have to modify again your settings which you already done beand restart the broker to take effect.
Babar
Share
Bill S. answered ·
I updated the agent...
java -jar dynatrace-agent-6.5.0.1289-unix.jar
We were on a bootstrap version 6.2 or 6.3 with a version of 6.5.15.1019.
I'm trying to understand why there's a discrepancy.
Share
Babar Q. answered ·
Hello Bill,
How did you upgrade the bootstrap agent?
Can you please explain a bit more?
Babar
Share
