question
Mark K. avatar image
Mark K. asked ·
The dtwsagent.ini file on my linux webserver is not configured yet the webserver agent is still able to connect to the collectorhost:9998 . Is there another setting that can provide the agent this connection information?
The dtwsagent.ini file on my linux webserver is not configured yet the webserver agent is still able to connect to the correct collectorhost:9998 . Is there another setting that can provide the agent this connection information?
configurationagentcollector6.1
1 Answer
Dustin L. avatar image
Dustin L. answered ·
Have you checked the agent logs? There should be a line which would indicate which configuration file the agent is using; it would look something like "[native] Reading configuration file..."
If you are using collector groups in your environment I wonder if could read the collectorlist file which should be under the .../agent/conf directory.
1 comment Share
Other thing to note at some accounts I have seen, the ini file is installed with localhost as the collector, if you are running a local collector for whatever reason this may explain it.
0 Likes 0 · ·
