question
connor m. avatar image
connor m. asked ·
Changes in UEM Agents from 6.5 to 7.0
Looking through Elasticsearch I see differences in the uri_stem of our UEM agents' request that correspond with the upgrade from 6.5 to 7.0. These slight differences are causing problems with our firewall white-list. Are there changes to the actual agent, and if so, would there be some documentation on this?
Thank you very much,
Connor
appmonagent7.0uemproductioncollectormigrationupgrade
1 Answer
Thomas K. avatar image
Thomas K. answered ·
Hi Connor,
can you add more details which specific URL. Do you mean the dynaTraceMonitor URL?
Best regards,
Thomas
Share
