I am trying to install easy travel application for demo/training purpose. Once I click on "Install System Profile" it gives me an error and the server is not getting connected. Please help.
Answer by Patrick H. · Jul 13, 2017 at 07:57 PM
The problem is not with easytravel, but with your dynatrace server.
Your Dynatrace Server is not running, thus you can't import the easyTravel Systemprofile.
Go to you services and make sure the Dynatrace Server and Frontend Server services are started.
Edit from my comment below:
You can find tutorials for the installation process and a lot more at the university.
Here is one for the installation on windows: https://university.dynatrace.com/discover/appmon/10209
Hi Patrick,
Can you tell me how do I start them from windows. I have viewed 'services' in windows and both server and frontendserver are not running there. Should I start them by running a .bat or a command? Please give me some steps.
just right click on each of them and select restart!
Hi Rajani, I said they are not running in 'services'. Where to right click ? Do you have any tips for running them ?
Do you mean from Services even if you right click on Dynatrace Server and Frontend Server and click restart they are not running?
Hi Rajani,
I mean if I go to 'services' I don't see any services named 'Dynatrace Server' or "Front end server" hence I can not right click and start them. Please see the screenshot of my services.
Looks like your Appmon Service is not running.
Can you try typing below command in Windows start menu:-
Start Dynatrace Server Service
Start Dynatrace Frontend Server Service
It should come up like this in screenshot.
Hi Rajani,
I am not getting anything after type both commands. I think I am not getting since the processes were not created at all. Do you have the steps to install the Easy Travel application in window7, 64-bit ? I am suspecting that something is missing in installation or configuration. Tell me what I need to adjust.
I think you can try reinstalling the Dynatrace full package but before doing that just make sure you uninstall existing one and completely delete Dynatrace folder from Program files.
After installing you can check from your Services both Dynatrace Server and Frontend Server should be running.
For Easytravel you can download it from below link
https://community.dynatrace.com/community/display/DL/Demo+Applications+-+easyTravel
I would try reinstalling like Rajanikanth suggested. Make sure you have administrator rights so Dynatrace can install the services.
Answer by Murthy M. · Jul 15, 2017 at 07:28 PM
Can anyone post a video/step-by-step process of complete installation in windows. The documentation was not explaining much. I am facing the same problem and cracking my head. Please someone help.
Learn key aspects on how Dynatrace helps you in your day to day web performance activities. Take a deep dive look into Real User Monitoring and the Synthetic capabilities of Dynatrace.
Thursday, April 26, 2018
Register today!
Register today!
Improve your operational efficiency and collaborate more effectively while addressing tightening security requirements. Have an early taste of what we have cooked up for 2018!
Learn more!
How to measure agent metrics (not purepath metrics) 2 Answers
sendModule() Exception: Connection time out during Agent startup - 730060 0 Answers
Custom traffic light (green color) when not have data. 1 Answer
Scala API causing slow transaction 2 Answers
Database Monitoring - moving from SCOM to Dynatrace 0 Answers
