question
Manish P. avatar image
Manish P. asked ·
Dynatrace list of incident rules
Hi
Is there a list available for all Dynatrace incident rules that can be exported and
once can choose incident rules that he is interested in to configure
6.5
James K. avatar image
James K. answered ·
The only thing even close at present that I am aware of is in the systemprofile xml files on the server there will be the xml for the incidents included if you have a way of parsing this to pull out the incidents, but there is no easy way to export and modify them. Would be a good RFE/Idea to post as I would find this very useful as well.
James
Share
HIMANSHU m. avatar image
HIMANSHU m. answered ·
hello @James K. , have we received any updates on this in latest version?
Is there a way now to pull List of incidents rules configured in a system profile?
1 comment Share
Hey Himanshu,
I recently did this, just import all the system profiles to a local directory. Inside the system profile XML are the incident rules defined. Powershell Script below gets all the incident rules with a mail action, and exports them to a Excel file.
Kind regards.
$filepath = "C:\System profiles"
$excel = New-Object -ComObject excel.application
$excel.visible = $False
$workbook = $excel.Workbooks.Add()
$diskSpacewksht= $workbook.Worksheets.Item(1)
$diskSpacewksht.Name = "Data Set"
$xindex = 1
Get-ChildItem $filepath -Filter *.xml |
Foreach-Object {
    $_.BaseName
   [xml]$xml = get-content $_.FullName
   foreach($incidentrule in  $xml.dynatrace.systemprofile.incidentrules.incidentrule){
      $diskSpacewksht.Cells.Item($xindex,1) = $_.BaseName
      $diskSpacewksht.Cells.Item($xindex,2) = $incidentrule.id
      $diskSpacewksht.Cells.Item($xindex,3) = $incidentrule.description
      foreach ($actie in $incidentrule.actions.actionref){
        if ($actie.type.Contains("mail")){
            [string]$mails = $actie.property.value
            $mails = $mails.replace("`n",", ").replace("`r",", ")
            if($mails -ne ""){
            $mails
                $diskSpacewksht.Cells.Item($xindex,4) = $mails
      $xindex++
$excel.DisplayAlerts = 'False'
$ext=".xlsx"
$path="C:\System profiles\newAllIncidents$ext"
$workbook.SaveAs($path)
$workbook.Close
$excel.Quit()
0 Likes 0 · ·
