question
Ram S. avatar image
Ram S. asked ·
MuleSoft monitoring in 6.5
Which agent do we need to install to monitor Mulesoft in V6.5? What is the configuration settings to follow? Which agent type do we need to choose while creating tier in profile.
6.5agent
Henry A. avatar image
Henry A. answered ·
Hi Ram,
I believe MuleSoft uses the Java agent to monitor.
You'll need to add the -agentpath parameter to the <MULE_HOME>/conf/wrapper.conf
Please see this below documentation for monitoring MuleSoft in 6.5
https://community.dynatrace.com/community/display/...
Best regards,
Henry
Share
Christopher A. avatar image
Christopher A. answered ·
Henry is correct but the link he posted is dead. The wrapper file would look like:
wrapper.java.additional.<n>=-javaagent:/dir/dynatrace/mule-4-agent.jar
<n>=sequential number from wrapper.conf
1 comment Share
Here's a link that works. This doc page says "v6.3", but it's the same for v6.5.
https://community.dynatrace.com/community/display/DOCDT63/Mule+ESB
0 Likes 0 · ·
