question
suraj g. avatar image
suraj g. asked ·
Is it possible to forward dynatrace dashboard data to splunk for analysis
6.5splunk
David N. avatar image
David N. answered ·
Hi Wai,
If you want to stream data other than the business transactions and UEM data, you would have to engineer a solution as there are no options provided by Dynatrace. There is a Splunk receivers stream that could be used to send data to Splunk.
http://docs.splunk.com/Documentation/Splunk/6.1.1/RESTAPI/RESTinput#receivers.2Fstream
For example, You could try scheduling a report from Dynatrace to be saved to a local directory (as a CSV or XML) and then use the receivers stream to load the text up to Splunk.
David Nicholls
1 comment Share
has anyone successfully imported a splunk dashboard into multiple events? I can get the xml data into splunk using REST data input but is one event. This is keeping me from extracting or associating metric values with the correct measure..
0 Likes 0 · ·
Wai C. avatar image
Wai C. answered ·
Hm.....data other than Business Transaction and UEM Data can also be forward to Splunk?
1 comment Share
The solution I had was to create a dashboard, usually containing a dynamic measure matrix, with the measures I wanted to import and run a CRON job to query the AppMon rest API on an interval and get the dashboard in CSV MWRT format to import into Splunk :)
0 Likes 0 · ·
David N. answered ·
Hello Suraj,
There are a few options for forwarding Dynatrace data to Splunk:
There is a plugin that is designed to send data splunk, you can read up on it here:
https://community.dynatrace.com/community/display/DL/Splunk+Application
There is also the real time business transaction streaming which is basically the same functionality as the plugin:
https://www.dynatrace.com/support/doc/appmon/integrations-and-extensions/realtime-streaming/
Finally, you can manipulate the REST interface to export the information that you want:
https://www.dynatrace.com/support/doc/appmon/appmon-reference/rest-interfaces/server-rest-interfaces/dashboards-and-reporting-rest/
David Nicholls
Share
