question
Mark K. avatar image
Mark K. asked ·
how do we get consistent Purepaths created when using the Spring @JMSListener and @RabbitListener annotations around specific methods (where the methods should start said Purepath
Some of our apps are messaging based, so the Purepath start point should be from the message listeners. For whatever reason, Product Feed seems to get picked up fine, but the other apps do not (even though they're all the same basic structure).
appmon7.0
1 Answer
David N. avatar image
David N. answered ·
Hello Mark,
Sounds to me like you need to do some Sensor placement in order to track those methods and then set them to start PurePaths. You can enter the system profile -> sensors -> add sensor group (top right icon) -> browse the class cache and select the relevant methods. Once this is done, you can edit the method and check the box to allow them to start PurePaths (note, this option is only available at the method level).
You will then have to add the sensor group to one of your agent groups under sensor placement. Once you do hot sensor placement or restart the app server component the sensor should be placed and new PurePaths will be started when the method calls are detected.
David Nicholls
Share
