Hello
could someone help me with question
how properly I must create Business transactions for monitor sub-action
I ran into the problem that AppMon does not recognize any Sub-actions as filters for BT
examples:
I have task to monitor redirect to another page after user click on some button in web-portal
After user click on button (mobileConfirmCode) we see Loadin_page user action (second user action)
For this user action I can see Target Page
Knowing the value of the Target Page, I can determine whether the redirect was where it was executed
I need to calculate the number of redirects for each possible type
I create Bussines Transaction for User-action Purepath
as a filter tried to used the metric - Page Action Name or User Action Count
But appmon do not collect PurePath accorging my settings
Whether it is possible to realize the given task or AppMon is not able it ?
Or better I need create support ticket
Answer by Chase H. · Oct 12, 2017 at 11:04 PM
It might be that you're using the wrong measures.
I'd try a measure like one of these.
Then you can set it using something like this. This should be an adequate filter. The OOTB count measure should give you what you're looking for.
Hello Chase
1. I used metric Count (User Action). But problems that my action is not first action during User Action PurePath and AppMon do not search it in business transaction
2. Web-reques not contain information about redirect.
3. Filters that you advise me to provide information about contain reg_static in URI. All my page contain it. It will be not work for my task. I mast look part of Anchor
Learn key aspects on how Dynatrace helps you in your day to day web performance activities. Take a deep dive look into Real User Monitoring and the Synthetic capabilities of Dynatrace.
Thursday, April 26, 2018
Register today!
Register today!
Improve your operational efficiency and collaborate more effectively while addressing tightening security requirements. Have an early taste of what we have cooked up for 2018!
Learn more!
