question
Shaohui L. avatar image
Shaohui L. asked ·
easyTravel Java Agent Offline issue
When do AppMon v6.5 training, one of trainees didn't find Java Agent in Agent overview dashlet.
As screenshot showed the agents were offline status when runing easyTravel Configuration UI with core training -> standard scenario.
Uninstall easyTravel and reinstalled it, the issues was the same.
Uploaded config and log information, please help.
customerfrontend-8080-0-0.log
easytravelconfig3170054384236206281properties.txt
appmon6.5agentjavawindow
Dennis M. avatar image
Dennis M. answered ·
Hi Shaohui,
a quick check revealed this in the logs:
2017-09-13 10:26:29 Custome INFO    [Tomcat7Starter] Directory does not exist: D:\Program files\Dyn_easytravel\customer\tomcat
2017-09-13 10:26:29 Custome INFO    [Tomcat7Starter] starting from webDir=D:\Program files\Dyn_easytravel\customer\webapp, tomcatDir=D:\Program files\Dyn_easytravel\customer\tomcat, workDir=D:\Users\huajunzhang\.dynaTrace\easyTravel 2.0.0\easyTravel\tmp\8080
You should always try to encourage people to install easyTravel in the default folders (e.g. C:/Program Files/Dynatrace), as some configurations otherwise won't work. I had a couple of trainings to learn that the hard way...
Best regards
Dennis
Share
Shaohui L. answered ·
Thank you, Dennis.
Share
