the customer asking us if is possible to show in a dashboard the percentage (only the numeric value) of the User Actions splitted by Apdex (% of satisfied, % of frustrated and % of tolerating).
could you suggest us how we can define this dashboard?
Thanks to all.
Answer by Andrea S. ·
Hi Patrick,
thanks for your answer.
I'm able to show in the dashboard the numeric value of other metrics (for example the User Action Response Time) using the "Text and Measurement Dashlet). I don't know how to define the metric (or the BT) needed for the customer's request.
The problem is the percentage values. You can define a BT to get the number of User Action per Apdex Zone, but only as absolute values, not as a percentage.
The only way I see to get a percentage is manual calculation using the variables features of the 7.0 web dashboard text and measure tile.
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
