Hello.
I have a question during the easyTravel Application test.
The Web service dashlet has a Failed column. However, this Failed column is always 0%.
I shutdown Backend Java Server. So the web services request is still failing.
However, the Failed column of the Web services dashlet is still 0%.
What exactly does the Failed column in the Web service dashlet mean?
Thanks.
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 12, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Register here
How to monitor asynchronous External API call with non http based protocol? 1 Answer
Visually complete for BT 1 Answer
Agent instrumentation is not available 2 Answers
BT/ Measures for UA 1 Answer
APPMon Server kernel Panic 1 Answer
