question
Carlos C. avatar image
Carlos C. asked ·
Can not access system profile
Hi Team,
We're now facing server access problem
When I modified system profile, I got "[BaseServerAccessController] Failed to access server: com.dynatrace.diagnostics.server.BaseServerAccessController$1 handle:71" in my server log
Restart server doesn't help, how can I fix this problem?
server00.log
server6.1system profile
server00.log (3.7 MiB)
1 Answer
James K. avatar image
James K. answered ·
This seems to occur when the system profile is out of sync with the server and performance warehouse. Sometimes though not always a server restart can resolve this. Unfortunately if this does not resolve the issue it has been better addressed/fixed to prevent that in more recent updates and releases but 6.1 has been out of support for quite a while now so may not have the fix in place (I imagine this is the case) so unless someone else has any tips the only thing I could recommend is to upgrade your deployment to a more recent supported version of AppMon.
James
1 comment Share
Thanks, restart server helps.
0 Likes 0 · ·
