question
Christian W. avatar image
Christian W. asked ·
Performance Data of DWH and Access by Rest-API
Hallo friends,
does anyone of you know how it is possible to get the performance data of the dataware house for working with those data at another program? Is this possible with the REST-API?
Thanks in advance. I already looked through this forum but I am not sure whether I found the right topic, so i thought it would be better to ask you directly.
Christian
appmonmonitoringappmon 7rest apiservicesinstallationdocumentationrest
James K. avatar image
James K. answered ·
No, there's no supported way of getting performance data warehouse directly. No API or anything like that. The only way to get the data directly would be to query it like any other database but since it's not a supported method of accessing the data you won't find any documentation on the table structure or anything and personally I wouldn't recommend it.
The closest workaround you can probably get is to use the API call to pull data from existing dashboards which you can create to have the relevant data you want loaded into them.
https://community.dynatrace.com/community/pages/vi...
Also, in case you're not aware this address on your server has a nice interface to see all of the calls and help construct them:
https://<yourserver>:8021/api-docs/current/
James
Share
Christian W. answered ·
Hello James,
thank you for answer.
Share
