question
Sandeep M. avatar image
Sandeep M. asked ·
Websphere transactions (Active, blocked, processing, runtime )
How can i create a dashboard for the websphere transactions like active, blocked, processing and runtime?
Tried creating a custom PMI measure but couldnt find them.
6.5appmonsaas
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello Sandeep,
Use the Java Management Extension (JMX) to manage and monitor Java-based applications. The JMX interface invokes methods on MBeans to retrieve Performance Monitoring Infrastructure (PMI) data. AppMon supports JMX and provides an interface for third-party applications integration.
https://www.dynatrace.com/support/doc/appmon/infra...
I tried with one of my application and I can see the required measure so just try to follow the instructions from the above link.
Babar
Share
