question
Andrea S. avatar image
Andrea S. asked ·
Tibco Support
our customer want to know if the following versions of Tibco are supported on AppMon 7.0:
TIBCO ActiveMatrix BusinessWorks 5.12.0 and TIBCO Runtime Agent 5.9.0
we have found in the documentation that TIBCO ActiveMatrix BusinessWorks is supported for the versions:5.8.2/5.9/5.10 but we did not find anything about TIBCO Runtime Agent.
can someone help us for this topic?
thanks
appmonagent7.0appmon 7productioncollectordocumentation
1 comment
Hi Andrea,
We have setup dynatrace agent for Tibco BW where we passed the dynatrace parameters in the .tra file
java.extended.properties=-agentpath\:/apps/dynatrace/dynatrace-6.1.0/agent/lib64/libdtagent.so\=name\= xxxxx,server\=xxxx\:9999
There is a plugin for Tibco BW.You can refer to the below link for Tibco BW.
https://github.com/Dynatrace/Dynatrace-AppMon-Tibco-BW-Monitoring-Plugin
But I didn't work with Tibco runtime agent.If tibco runtime agent is similar to BW and have .tra file you can pass the dynatrace parameters and it may work.
Tarun
0 Likes 0 · ·
