question
Rodrigo A. avatar image
Rodrigo A. asked ·
REST dashboard JSON
I just migrated from AppMon 6.3 to 7.0. Some externasl resouces were accesing via REST to a dashboard, retrieving the data in JSON format.
with this query /rest/management/reports/create/DASHBOARD_REMOTE/?type=json
but now seems that this is not working. It just responds with formats like XML, CSV...
(/rest/management/reports/create/DASHBOARD_REMOTE/?type=xml)
Is the JSON format gonne? Or there is some workaround to get it in JSON format?
Regards
dashboard7.0rest
1 Answer
James K. avatar image
James K. answered ·
I don't see json listed as a supported format for 7.0 or 6.3.
Perhaps you were using this plugin and just need to reinstall it?
https://community.dynatrace.com/community/display/...
James
1 comment Share
Thank you at the end seems that those request were done with that pluging
0 Likes 0 · ·
