question
Neji G. avatar image
Neji G. asked ·
easyTravel-Docker installation problem
Hi guys,
I have got the following error when starting the easyTravel docker image :
ERROR: Service "backend" mounts volumes from "dtagent", which is not the name of a service or container.
I'm using the last version in github.
The command i use to start the image is : docker-compose -f docker-compose-withDtAppMon.yml up
When using the docker-compose up command the backend took a lot of time without starting .
Any help would be appreciated !
installationdocker
1 comment
Moved to the AppMon Open Q&A forum.
0 Likes 0 · ·
