question
Vincent C. avatar image
Vincent C. asked ·
Web server Deamon doesn't start in my docker contener
I'm trying to start WebServer deamon in a docker contener.
Unfortunately contener starts but deamon doesn't.
I have this log :
cat dt_dtapacheagent24bo_CARE_dtwsagent_10.0.log
2018-02-23 16:25:02.095985 [10/2c9ca7ca] info [native] Reading configuration file: /opt/appmon/dt/agent/conf/dtwsagent.ini
2018-02-23 16:25:02.096318 [10/2c9ca7ca] info [native] Initialized logfile: /opt/appmon/dt/log/dt_dtapacheagent24bo_CARE_dtwsagent_10.log
2018-02-23 16:25:02.096397 [10/2c9ca7ca] info [native] Max. logfile size: 10485760 bytes
2018-02-23 16:25:02.096404 [10/2c9ca7ca] info [native] No sharedmemoryfilename directive supplied in configuration. Using default.
2018-02-23 16:25:02.096409 [10/2c9ca7ca] info [native] No port directive supplied in configuration. Using default: 0
2018-02-23 16:25:02.096471 [10/2c9ca7ca] info [native] Using SHM location: /opt/appmon/dt/agent/conf/dynaTraceWebServerSharedMemory
2018-02-23 16:25:02.097658 [10/2c9ca7ca] info [native] Initializing config data in fresh shared memory file /opt/appmon/dt/agent/conf/dynaTraceWebServerSharedMemory.
2018-02-23 16:25:02.100224 [10/2c9ca7ca] info [native] -------------------------------------------------------------------------------------------------
2018-02-23 16:25:02.100240 [10/2c9ca7ca] info [native] dynaTrace Agent for Apache Web Server Copyright (C) 2004-2017 Dynatrace, http://www.dynatrace.com
2018-02-23 16:25:02.100248 [10/2c9ca7ca] info [native] -------------------------------------------------------------------------------------------------
2018-02-23 16:25:02.100257 [10/2c9ca7ca] info [native] Version ..................... 7.0.17.1015, build date Feb 7 2018 12:44:01, svn rev. 774425
2018-02-23 16:25:02.100265 [10/2c9ca7ca] info [native] SHM layout .................. 7.0.0.368
2018-02-23 16:25:02.100297 [10/2c9ca7ca] info [native] Command line is /usr/sbin/httpd -DFOREGROUND
2018-02-23 16:25:02.100306 [10/2c9ca7ca] info [native] Build platform .............. Linux x86 64-bit
2018-02-23 16:25:02.100313 [10/2c9ca7ca] info [native] Platform .................... Linux 3.10.0-514.16.1.el7.x86_64 x86_64
2018-02-23 16:25:02.100318 [10/2c9ca7ca] info [native] Bootstrap version ........... 7.0.0.2469
2018-02-23 16:25:02.100322 [10/2c9ca7ca] info [native] Log level console ........... none
2018-02-23 16:25:02.100325 [10/2c9ca7ca] info [native] Log level file .............. info
2018-02-23 16:25:02.100329 [10/2c9ca7ca] info [native] Log file .................... /opt/appmon/dt/log/dt_dtapacheagent24bo_CARE_dtwsagent_10.0.log
2018-02-23 16:25:02.100453 [10/2c9ca7ca] info [native] Apache MPM settings:
2018-02-23 16:25:02.100462 [10/2c9ca7ca] info [native] - MPM module: prefork.c (from a DSO)
2018-02-23 16:25:02.100468 [10/2c9ca7ca] info [native] - ServerLimit: 256 [procs]
2018-02-23 16:25:02.100472 [10/2c9ca7ca] info [native] - MaxClients==MaxRequestWorkers: 256 [procs]
2018-02-23 16:25:02.100476 [10/2c9ca7ca] info [native] - MinSpareServers: 5 [procs]
2018-02-23 16:25:02.100479 [10/2c9ca7ca] info [native] - MaxSpareServers: 10 [procs]
2018-02-23 16:25:02.100483 [10/2c9ca7ca] info [native] - MaxRequestsPerChild: 0 [reqs]
2018-02-23 16:25:02.100547 [10/2c9ca7ca] info [native] Default injection filter placement: false
[root@1df5bdfa1139 log]#
My configuration for setting isMasterAgentServiceInstalled is true
Could you help me ?
configuration7.0appmon 7docker
