question
Ashutosh S. avatar image
Ashutosh S. asked ·
REST Client is not access
Dear Team,
Recently i have upgraded my APM server from 6.5 to 7.0. But I can access web dashboard on port 9911 but unable to access REST API portal on port 8021.
I am getting below logs as well:
INFO [ServerServiceTrackerCustomizer] Starting HTTP Server
2018-03-05 15:07:51 INFO [SecuringJettyModule] Removing unsafe ciphers from Jetty instance at port 8021: [SSL_DHE_DSS_EXPORT_WITH_DES40_CBC_SHA...........[continues]
2018-03-05 15:07:51 INFO [SecuringJettyModule] Removing unsafe protocols from Jetty instance at port 8021: [SSLv2, SSLv3, SSLv2Hello, TLSv1]
2018-03-05 15:07:51 WARNING [ServerServiceTrackerCustomizer] HTTP Server listener(s) cannot be started, please edit server.config.xml for alternative ports.
Kindly check and provide solution for same.
Ashutosh Singh
7.0rest apirest
1 Answer
Ari P. avatar image
Ari P. answered ·
Hello Ashutosh,
Have you checked to make sure that the port 8021 is not being used by some other process? Was this working when you were on 6.5?
Share
