question
Winkle K. avatar image
Winkle K. asked ·
Unable to consume Appmon REST API for alert suppression
Hi Team,
I am taking reference from " https://www.dynatrace.com/support/doc/appmon/appmo... " URI and trying to suppress the incidents during business hours.
1. Created business hours definition where System profile was Test1 an Business hour name was test
{ "inclusions": [ { "timespan": { "start": "07:00", "end": "16:00" }, "weekdays": [ "MON","TUE","WED","THU","FRI" ] } ] }
02. validated the business hour creation after consuming Get /profiles/{profileid}/businesshours API, I was able to validated that out
Response Body:
{ "businesshours": [ { "id": "7_to_16", "href": "https://dtrace-2:8021/api/v2/profiles/Test1/businesshours/7_to_16" }, { "id": "test", "href": "https://dtrace-2:8021/api/v2/profiles/Test1/businesshours/test" } ] }
03. Create alert suppression -> is throwing 404 error in the response body
{ "systemprofiles": [ { "systemprofile": "Test1" } ], "businesshours": "test" }
Response Body:
{ "code": 404, "message": "Business hours reference 'test' could not be found." }
Please find the attached screenshots for the same, Need your immediate help on this.
Thanks in advance
Winkle khurana
alertingrest apirest
Winkle K. answered ·
Hi Ari,
I have raised this concern with the Support team, they are also facing the same issue and will report this to R&D team to check however they have suggested to use the below workaroung to configure Appmon downtime using below URL
https://www.dynatrace.com/support/doc/appmon/application-monitoring/incidents-and-alerting/incidents-downtimes/
Thing is no such attribute found in order to suppress the downtime based on business hours, Any Idea.
2 comments Share
Thanks for the update. Any chance you can link the support case here too?
0 Likes 0 · ·
No, However will share the feedback from the support.
0 Likes 0 · ·
Ari,
7_to_16_suppress is the incident downtime name for the test1 System Profile, based on the test business hours (Tried using 7_to_16 business hour still the same response)
2 comments Share
I actually tried replicating the whole scenario and am facing the same issue. So I'm not really sure what the issue here is. Do you have the ability to open up a support ticket? I would recommend doing that if you can't more help here.
0 Likes 0 · ·
Thanks Ari,
Waiting for someone to answer that. Still if the issue exists will open support case.
Thanks a lot for your time and support
0 Likes 0 · ·
Ari P. avatar image
Ari P. answered ·
In your screenshot, the businesshours in your body says 'test' but the endpoint says '7_to_16_suppress'
Make both of them consistent and see what happens. Additionally, why are you adding "_suppress" at the end? You don't have that in the validation response of the business hours.
Share
Hi Ari,
I have tried the same, still the same issue.
Share
Ari P. avatar image
Ari P. answered ·
Hello Winkle,
Trying using "businesshours" : "7_to_16" (instead of "businesshours" : "test") and see if that makes a difference.
Share
