question
Roberta D. avatar image
Roberta D. asked ·
see cookie
In my dynatrace would to insert a cookie but how can you see the cookies inserted?
monitoringbusiness transactiondatabasehybrismessagebroker
Babar Q. avatar image
Babar Q. answered ·
Hello Roberta,
The quickest way to verify the dt related cookies after enabling the UEM is the browser developer mode.
Click on XHR > dynaTraceMonitor > Cookies e.g. to see the below information.
Secondly you can enable the Cookie in the 'Request Headers' of the Servlet, ASP.Net etc to see in the method...
Babar
Share
Consultor I. avatar image
Consultor I. answered ·
Hi @Babar Q.
Do you know how much time does the session are configured to stay in cookie in Dyanatrace Managed?
I could reach the cookies, but there is no informantion about cookie time.
Thanks.
Best regards.
1 comment Share
Hello @Consultor I.
To identify a visit, AppMon uses cookies. Therefore it is a technical necessity that a Webserver Agent set a temporary session cookie; otherwise UEM cannot measure a user's performance experience. This cookie is sent on the first web request and expires when the browser is closed. It is non-persistent and is not used for ad tracking. AppMon sets these first-party cookies for the sole purpose of application performance management, not for tracking a user's purchasing bias or click behavior.
Review the below links for more insight.
https://www.dynatrace.com/support/doc/appmon/data-privacy-and-security/privacy-and-security/cookies/
https://www.dynatrace.com/support/help/data-privacy-and-security/data-privacy/how-does-dynatrace-use-cookies/
Babar
0 Likes 0 · ·
