question
Torsten H. avatar image
Torsten H. asked ·
Use new AppMon agent directly
Hi all,
is there any way to use the new AppMon agent for Apache without installing classic first and the switching? I have a customer who has severe problems (caused by security guys) to include an Apache module that does not reside inside there central modules folder. Since this modules folder is a flat directory I can't just install the dynatrace web server agent in there.
Torsten
agentappmon 7apachewebserver
1 Answer
Patrick H. avatar image
Patrick H. answered ·
Hi Torsten,
I did a short test after we talked about it. In 7.1, if the Agent Group is set to use the AppMon platform, the Apache agent automatically connects with the AppMon platform, even though the webserver agent service is stopped:
I Purged the agent, easyTravel and the SystemProfile before the test, so this should work.
1 comment Share
Hello @Patrick H.
I wanted to check the same in the pre-production environment but unable to find the location which you shared as screenshot.
Can you send me the steps?
Babar
0 Likes 0 · ·
