question
Roberto R. avatar image
Roberto R. asked ·
PHP Custom Sensor configuration
Hi all,
I would a detailed monitor for one method but for now all my attempts don't works.
The method is the one selected on this image:
I've set the sensor rule like this:
I can't understand what could be te mistake in the configuration.
Can someone help me?
Thanks in advantage,
Roberto
6.5sensorphpsensors
Peter K. avatar image
Peter K. answered ·
I might be wrong, but I think that the "F" in the icon to the left of the purepath indicates a function. Maybe you could try to create both, a "function" and a "method" rule and see if it helps?
Share
Roberto R. answered ·
Hello Peter,
I've tried this workaround but it didn't help, the situation is still the same.
I really don't know which could be the problem..
Best Regards,
Roberto
2 comments Share
Have you tried without the parenteses () ?
0 Likes 0 · ·
Yes, but also with this modify is still not working.
0 Likes 0 · ·
Joe H. avatar image
Joe H. answered ·
Roberto,
I see a few things that might be wrong, however without full access to your profile it is hard to know exactly. So I'm providing several things to try.
1) You're specifying to capture Argument #1, however I can't tell if there really is an argument in this method. If there is not, then remove the "1" from the "Capture Arguments" field.
2) You're specifying "Equals" as a match criteria for the class definition. Are you sure this is the full classname? Try "Contains" pattern match.
3) You're specifying "End" as a match criteria for the method. Try "equals" or "Contains".
Hope that helps.
joe
Share
Hi Joseph,
thanks for the reply. I've found the mistake in my configuration: simply the PHP path was wrong. I've spent a lot of time by finding the correct one since my collegue was unable to tell me a defined one.
Thanks to all!
Roberto
Share
