question
Vaclav S. avatar image
Vaclav S. asked ·
Oracle measures do not show
maybe the answer to the question I am going to ask is obvious but I cannot figure it out. Can you give me a hint why I cannot see any Oracle measures gathered by Dynatrace? Do I miss something here? The the api uses hibernate to manage oracle connection - maybe I need to activate it first? If I navigate to metrics: Database monitoring - Oracle db monitoring, I pick any measure and try to add it to a chart, but it appears there is no data at all. What is strange it seems that on the transaction flow it shows it.
dashboardpluginsmonitoringdatabasemeasuresframeworkwindow
