question
Mayana K. avatar image
Mayana K. asked ·
Issues in Uninstalling of old dynatrace clients
I am facing issues in uninstalling of old dynatrace clients 5.5/6.1/6.5. To uninstall it require the setups ?
Mayana khan
6.5client6.26.1
1 Answer
Florent D. avatar image
Florent D. answered ·
Hi
it is worth checking that these clients were not installed via the portable client. If that the case, windows would have no information about it as it is just a zip file and not an MSI.
Regards
Flo
2 comments Share
Hi @Florent D.
I am not sure how they were installed these clients. For Un-install do we need to copy the setup to desired location?
0 Likes 0 · ·
if the uninstaller doesn't work, simply delete the file system where they have been installed. Typically c:\program files\dynatrace\dynatrace x.x
0 Likes 0 · ·
