question
Fabio L. avatar image
Fabio L. asked ·
Containerise AppMon
Hi All,
I would presume that this indeed possible. I already have a working image with AppMon and am able to run containers.
To make licensing work I have created a Docker network and assigned each container a static MAC and IP address.
However, would you be able to confirm what directories need to be mounted as persistent volumes? At the moment I have only this one:
/opt/dynatrace/appmon/server/conf
configuration7.1installationlicensedocker
1 Answer
Thomas K. avatar image
Thomas K. answered ·
Hi Fabio,
there are already some scripts / config, maybe this helps:
https://github.com/Dynatrace/Dynatrace-AppMon-Dock...
Note that it is a lot more complicated to configure persistent volumes. The server, collector etc make a lot of changes all around the installation folder place.
Eg: /log/ for logging (can be reconfigured). The .ini files in the root. A lot of files in the /server/ outside the conf folder. Pid-files etc.
Best would be likely to consider the whole install directory as potentially changing and holding configured data.
Best regards,
Thomas
Share
