question
Israel L. avatar image
Israel L. asked ·
.NET Agent Configuration
Some solution for this:
2018-05-16 03:49:47 [00000640] warning [native] Unable to get instance name for Performance Counters (this might be a permission issue of the monitored process).
2018-05-16 03:49:47 [00000640] warning [native] Performance Counter initialization failed, Performance Counter measures will not be available.
2018-05-16 03:49:47 [000005d0] info [native] Controller channel connected successfully
2018-05-16 03:49:47 [000005d0] info [native] Eventsender channel connected successfully
2018-05-16 03:49:47 [000005d0] info [native] Using default Managed Sampling.
2018-05-16 03:49:47 [000005d0] warning [native] module send failed: error code 500
2018-05-16 03:49:47 [000005d0] info [native] Average transformation time for 1 classes/modules was 27ms - maximum set to 60000ms
2018-05-16 03:49:47 [000005d0] warning [native] Profiler::ModuleLoadStarted(): Cannot process assembly c:\windows\microsoft.net\assembly\gac_64\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll.
2018-05-16 03:49:47 [000005d0] warning [native] Failed to transform assembly - stopping instrumentation
2018-05-16 03:49:53 [00000640] info [native] License = license ok;
appmonconfiguration6.5agentdotnet
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello Israel,
Go throug with the below steps.
  • If an already running process has just been configured, a process restart is necessary.
  • Make sure the agent can connect to the Collector. Review the Bootstrap Agent log for more information.
  • Check whether the environment variables COR_PROFILER_PATH and DT_AGENTACTIVEare set, and unset them. A process restart or system reboot is necessary.
  • Make sure the process receives web requests. If it does not, CLR and the core agent are not loaded in the process.
Review the below link for more status messages and the possible solutions.
https://www.dynatrace.com/support/doc/appmon/insta...
Babar
Share
