question
Dwayne F. avatar image
Dwayne F. asked ·
Question about Agent filters on Purepath Response Time
I created a Purepath Response Time measure and enabled the option to ‘create measure for each agent’. My question is the following. Let's say I have agents on Components A, B and C. When I chart the purepath response time measure and filter to only include the agent on Component A, what does it actually chart? Is it:
  1. The overall response times/durations for ALL purepaths that hit Component A?
OR
2. The contribution to the purepath response time by Component A?
Dwayne
dashboardagent7.0appmon 7reportsmeasuresdashlet
1 Answer
Andrey S. avatar image
Andrey S. answered ·
Hello
Duration of a All PurePath from the entry event to the exit that hit Component A
Share
