question
akshay s. avatar image
akshay s. asked ·
Web requests are not tagging to User actions.
Can someone throw some light as why User Action in visit showing lots of actions as a web request?
Questioning this because, as per the AM team end users are facing huge slowness for this application & AppMon is showing just 3-5 sec response time.
And I suspect that some of user actions are showing as web requests ( & not as a user action) and hence overall response shown by AppMon for each visit is much lower than the end users are actually experiencing.
BR,
AK
6.5uem
Alexander R. avatar image
Alexander R. answered ·
Hello akshay s.
I think you can try change configuration:
for this configuration you need switch to debug mode CTRL + SHIFT + F9
it is necessary to know - how exactly "single page application" works. You can try to change a configuration - and look at result in Visits dashlet.
1 comment Share
Hi Alexander,
i am facing similar issue, but i could not find the configuration mentioned in the screenshots in debug mode. Can you give more details/path to change the configuration.
i Can see the Applications in Dynatrace navigation. But when i open my application, there are no setting i see to change for XHR. Please suggest.
My Dynatrace version is -7.0.24.1011
Shankar.
0 Likes 0 · ·
Andrey S. avatar image
Andrey S. answered ·
Hello
Is it single-page application?
Or maybe are users working in some Form which next sent rest web-requests?
Which kind of agents do you have on your application tiers?
1 comment Share
Hi Andrey,
Yes, the application is single page & some users directly login to EBS and access oracle forms.
but in that case Rest web-request will not be used.
AppMon instrumented for oracle application having OHS (web agents used) & weblogic (java agents used).
BR,
AK
0 Likes 0 · ·
