question
Sreedhar M. avatar image
Sreedhar M. asked ·
Is it possible to compare the yesterday's data in a dashlet in dashboard view ?
HI All,
Is it possible to compare the todays data with yesterday's data in dashlet of a dashboard in Appmon with some line view or something to see if it has any deviations?
Sree
dashboard7.0appmon 7dashlet
Peter Z. avatar image
Peter Z. answered ·
multiple ways are possible:
ideally you would create a web dashboard and use the comparison timeframe:
Or in the Client, create a dual axis chart and select a comparison TF for the right Y axis
Best,
Peter
4 comments Share
Thanks Peter!
In web dashboard view in advanced settings for comparison timeframe can't we show on the same dashlet? Also when i tried comparison timeframe am getting single dashlet not like in your screenshot above. Please let me know if am missing something.
Sree
0 Likes 0 · ·
hi Peter,
Please find the screen shot below. Am trying to chart sum of failures from Business Transaction. In left Y Axis i have selected the failures which has 30 splits and in Right Y Axis again i have selected same failures measure without splitting assuming as i need total sum as single line from yesterday's. But it's just matching with both the charts. Please correct me if am missing something here,
Sree
0 Likes 0 · ·
hi All,
Is it possible to add Count and failures in one axis and Count of yesterdays data in another axis?
Sree
0 Likes 0 · ·
Hello @Sreedhar M.
This is not possible in the same tile but you can have two parallel tiles to compare specific timeframe.
Babar
0 Likes 0 · ·
Uros D. avatar image
Uros D. answered ·
Hello everybody,
Does it possible to do this with Dynatrace managed ? I.e. to compare two different date source on the same chart ?
Thank you in advance,
Uros
Share
