question
Sudhakara R. avatar image
Sudhakara R. asked ·
Application process shutdown - customize alert based on a set of hostnames (server/agent)
Hi, Is there a way to customize the "Application Process Shutdown" alert in Dynatrace AppMon v7.x based on a set of hostnames (agents). Like, I have 700 agents added to a system profile for monitoring and few agents are out of scope from alerting. Hence, I want to exclude the unwanted agents and just enabled the "Application Process Shutdown" for agents/hostname that starts with the name "apgw_".
Is there a feasibility in DT AppMon to achieve this.
Thanks in advance for your response!
alerting
Mahesh M. avatar image
Mahesh M. answered ·
i have tried creating Hostgroups and customized alerts for a group. However some of them are still not working as expected. is there any way to create groups for all JVM's instead of a Host ?
Share
Ari P. avatar image
Ari P. answered ·
Hello Sudhakara,
Have you looked into creating Hostgroups? You can do this by going to the 'Infrastructure' tab in your Server settings. Once you created a hostgroup, you can alert off of them one of which includes 'Host/Process Availability'.
Here's a screenshot of what i'm talking about (12c Hosts CHA-A is one of our host groups):-
Share
