question
Amit K. avatar image
Amit K. asked ·
Agent not instrumented properly
Hi all,
I am trying to configure Appmon with docker. I have a java agent that is failing to initialize and see the following error message :-
018-06-16 03:45:45 [75448818] warning [native] Agent not instrumented properly, license cannot be verified 2018-06-16 03:45:45 [a74fc818] info [native] License = skipped by license check - agent did not match a system profile;
I have a valid license.
appmondocker
1 Answer
Arturo R. avatar image
Arturo R. answered ·
agent did not match a system profile -> Be sure you have a correct agent mapping to have the data matched to a system profile. Check this first (is not the first time the matching criteria make me be confused!)
Share
