question
Abhishek B. avatar image
Abhishek B. asked ·
Dynatrace Saas or Dynatrace Appmon 7.x Integration with on premise Splunk 7x
Hi All,
Does anyone integrated events from Dyantrace Saas/Dynatrace AppMon with on premise splunk 7x ?
Kindly share some documents or ideas around it .
Abby
appmonappmon 7appmonsaassplunk
Abhishek B. answered ·
Hi Kyle,
I am trying to push incidents from Appmon 7.1 to Splunk 7.1 using the above plugin . Also I have Set the url to http://<splunk host>:80 in the plugin and also provided the splunk credentials. Even I tried with the port no 4321 but still I am not getting any alert in splunk . Am i doing something wrong ? Any inputs will be very much appriciated.
With Regards,
Abby
Share
Kyle K. avatar image
Kyle K. answered ·
Hi Abhishek,
Have you checked our Splunk plugin page for App Mon? This should help you get set up in the App Mon world. For Dynatrace you would have to set up a web hook and utilize our user session export feature.
HTH,
Kyle
Share
