question
Andrey R. avatar image
Andrey R. asked ·
Elasticsearch error to apply dynatrace template - Datastartime not date type
Hi Guys,
I followed all steps at PureLytics Stream but when I tried to create a template I received the error below:
  "error": {
    "root_cause": [
        "type": "illegal_argument_exception",
        "reason": "Rejecting mapping update to [E_hv0GaVSFqeoM1hPzCEKg] as the final mapping would have more than 1 type: [clienterror, useraction, visit]"
  "status": 400
Elastic 6.2.1 and Dynatrace 7.1.4
My problem is that in Kibana/elasticsearch the dataStarttime and Endtime is not a date type.
Thanks in advance.
Andrey
dashboard7.16.2purelyticskibana
Babar Q. avatar image
Babar Q. answered ·
Hello Andrey,
Apply the dynamic template version 6 for Elasticsearch 6 to the cluster from the below link and adapt the number of shards to the number of your data nodes.
https://www.dynatrace.com/support/doc/appmon/integ...
Babar
Share
Andrey R. answered ·
Thanks Babar works good!
6 comments Share
Hello Andrey,
I need your assistance in case you successfully implemented the solution.
Babar
0 Likes 0 · ·
Sure, Babar. If you need sent me a particular email, about solution I did all steps in 'PureLytics Stream' the difference is a template that you sent to me in another Purelytics (link).
Regards, Andrey.
0 Likes 0 · ·
Hello Andrey,
Thank you for offereing the help. Please share the email with me, thanks.
Babar
0 Likes 0 · ·
Sure,
Andrey
0 Likes 0 · ·
Hello Andrey,
Please share with me the steps you have taken for the successful data streaming.
Babar
0 Likes 0 · ·
Hello @Andrey Rafael I. @Andrey Rafael I.
My email address is babar.qayyum(@)live(.com)
Babar
0 Likes 0 · ·
