question
Luiz N. avatar image
Luiz N. asked ·
How to monitors all service requests of PostgreSQL?
I want to monitor a PostgreSQL database at the code level, as the documentation indicates.
However, even with the one agent configured and PostgreSQL's Dynatrace plugin enabled (Image 1), the database is not monitored as expected (Image 2).
Image 1: PostgreSQL's Dynatrace plugin setup
Image 2: Database monitoring page message
Image 3: Process page
agentmonitoringdatabaseservicesinstallationweb dashboardpostgresql
1 Answer
Jakub M. avatar image
Jakub M. answered ·
In order to see database services you need to install OneAgent also on host where your application is running. Then you should see SQL requests. We support all main languages https://www.dynatrace.com/support/help/technology-support/supported-versions-and-environments/which-environments-and-versions-does-dynatrace-support/
Share
