One our end user is trying to increase the heap memory of is Appmon client 7.0 but whenever he updates and restarts client, settings don't change. I told him to uninstall and reinstall it or use dynatrace portable client but still no luck.
Answer by James K. · Jul 11, 2018 at 01:26 PM
I would check the environment variables set on the user's machine. There are some such as JAVA_OPTS, JAVA_OPTIONS, or JAVA_TOOL_OPTIONS (depending on the JVM vendor) where if a -Xmx is set it can override the values you set in the client or ini file.
James
Hi James,
You were right, in Enviornment variables it was using JAVA_OPTIONS which was causing it to be static. user removed and then it worked.
Answer by chiranjit D. · Jul 11, 2018 at 07:26 AM
He is using Rich client only, but whenever he tries to change the heap memory and restarts it, it doesn't change but when he check the dtclient.ini there the change is reflected.
Hello Chiranjit,
Do you mean changes are reflected in the dtclient.ini but not in the client after restart?
How much memory he has on the host and how much he is assigning to the client?
Babar
Answer by chiranjit D. · Jul 11, 2018 at 07:57 AM
Yes Babar,
Changes are not reflecting in client.
he has 16G for ram and trying to assign 2048 or 3084 but nothing is working out. He also has admin rights to his machine, so i don't think its access issue.
Hello Chiranjit,
Just try with the 3072 MB instead of 3084 MB.
Babar
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
