Answer by Joseph H. · Jul 11, 2018 at 04:02 PM
You can also copy/paste resources between profiles.
For example. in D4, copy a given BT (or sensor rule, or Agent Group, etc), then open D7 and paste the resource. This is useful for moving individual resources between profiles.
Answer by Ravi D. · Jul 11, 2018 at 12:12 PM
Hi Hema,
For D4 System profile and D7 if you need same kind of configuration like Sensor packs, Incidents, measures etc., then you can export the system profile D4 to the xml file --> while saving the file rename it to the D7 and then import the file name.
Here for example, I have exported the system profile RC2 and saved it to the RC2_Test and imported it back to the AppMon server.
Steps:
1)Under System profile Right click on D4--> Export to System Profile
2)Save the file to the D7.profile.xml
3)Import the file by right clicking on the system profile and select the file D7.profile.xml
Note: If you have different agent groups in the D7 you need to modify them
Ravi
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
Seeing confidential userids in argument of PurePath... option to turn off? 4 Answers
Does Dynatrace supports Mulesoft 3.9 ? 1 Answer
Performance Warehouse migration - SQL Server 1 Answer
RFE - NGINX Support Update (1.13) 0 Answers
Help setting up TLS 1.2 connection to Performance Warehouse 0 Answers
