question
Cesar Z. avatar image
Cesar Z. asked ·
Configure an alert of key services on Dynatrace SaaS
I have a dashboard on Dynatrace SaaS with key services request (count) metric and I want to create a problem notification of it with a specific threshold, for example alerting for above 40 request. I found the configuration of "service request" in "Settings/Anomaly detection/Custom alerts" but inside of service I've some key services and I don't want to notification of these, only one specific key services. Is possible the configuration?
Regards
servicesmeasures
1 Answer
Gabriel C. avatar image
Gabriel C. answered ·
Hi Cesar,
Try going to Transaction and Services -> Select your desired service -> Edit -> Anomaly Detection and scroll down to see the key requests there. You can set custom thresholds for each one of them separately.
Take a look at the screenshot below as an example, and let me know:
If doesn't appear to you, please check your Dynatrace Version.
1 comment Share
Hi Gabriel, Cesar is asking for request count (throughput). I only see failure rate and response time in the screenshot you've provided. I'm interested to know if there are any workaround for this as I'm also looking for throughput alert based on key request.
0 Likes 0 · ·
