question
Saqib M. avatar image
Saqib M. asked ·
Unique visit count in Business transaction
I have set up some business transactions. Now the BT are giving me proper results. But what i want is unique customer visit for that particular business transaction.
E.g: There is a BT on login. Now same users can login multiple times within a day. Is there a way I filter the BT such that it can give me the unique user visits on the day only and display this value in a dashboard?
Any help will be much appreciated.
Thanks and Regards,
Saqib Mukri
appmondashboardbusiness transaction7.1web dashboarddashlet
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello @Saqib M.
Yes. You can have this information but make sure you should avoid the excessive splitting results, also known as measure explosion, can cause the Performance Warehouse to fill up, so additional data cannot be written to the Performance Warehouse. AppMon detects misconfigured Business Transactions and disables creating measures for them, to prevent excessive data.
You will have to create a custom measure to get the unique user and use in the splitting are of the business transaction e.g. below screenshot.
Babar
2 comments Share
Hi @Babar Q.
Thanks for the reponse. So to what I understand basically for each business transaction that I have I need to split based on the unique ID for that particular BT and I should be getting the result.
Is my understanding correct?
Thanks and Regards,
Saqib Mukri
0 Likes 0 · ·
Hello @Saqib M.
I am not sure about the other business transactions you referring but to have something unique like users we will have to do the splitting.
Babar
0 Likes 0 · ·
