question
Sangeetha M. avatar image
Sangeetha M. asked ·
Hi team,dynaTraceMonitor?bwstate=* ??
What is this error? what is mean by this? Actually I could see this particular error in network logs.
with this error application team is telling their main urls of the application is taking much time
So what I do from my side to resolve this issue ?
Are we having any disable options for this improve the performance of the application?
agent7.0client6.2
1 Answer
Ravi K. avatar image
Ravi K. answered ·
Hi Sangeetha,
It's not an error, an option which is enabled to know the network bandwidth detection. Yes, you have an option to disable this. Your client suspect might be correct here, as this option loads the images of sizes varying from 0K to 1000K (1MB) to know the bandwith based on the download time.
Please find the below URL which has more information.
https://www.dynatrace.com/support/doc/appmon/short...
HTH,
Ravi
18 comments Share
Thank you:) How to disable can you tell me path right its an high alert for infra team
0 Likes 0 · ·
Hi Sangeetha,
Go to System profile settings --> User Experience--> Switch to the Specific application on which you need to disable the Bandwidth --> Scroll down and under the --> Web application settings --> you can find the below option.
Un check the below both options
HTH,
Ravi
0 Likes 0 · ·
Hi Ravi thank you:) I hvae not configure any application ..So can I disable bandwidth for default application ? Is it going to work?
0 Likes 0 · ·
Yes, it will work and make sure you are under the system profile on which you are meant for these changes.
Ravi
0 Likes 0 · ·
haa ok. Ravi thank you:) In user experience-->default application-->web applications
we have an option like load the java script agent asynchronously ..what does it ? if I check in did it going to impact on end user access?
one more doubt
Injected java script agent version(latest) we have a drop down here,
Actually my setup is except agent all are 7.0.2 version appmon components.
agent version is 6.2..if I drop down the version table 6.2 is not appearing .
In this case what I need select?
0 Likes 0 · ·
Hi Sangeetha,
Java script agent asynchronous injection doesn't block the page loads. However, it has some draw backs in collecting the actions triggered by the scripts especially for jQuery and AngularJs, as it is injected asynchronously .
Below link has the same info..
https://www.dynatrace.com/support/doc/appmon/shortlink/id_javascript_agent_injection#asynchronous-injection
For your second question, seems you are mentioning that - JS agent is old version. Please paste the snapshot for better understanding.
Ravi
0 Likes 0 · ·
My java agent is of 6.2 version which is older but If I go with current version it will not going to support the application server. So that is why I am asking injected java script version(latest) what I need to select?
0 Likes 0 · ·
Hi Sangeetha,
As your application doesn't support the latest appmon 7.x, you can still use the earlier java script agent 6.2. Some features and functionalities introduced in new version may not be available for you, as you would be using the old version.
https://www.dynatrace.com/support/doc/appmon/shortlink/id_agent_compatibility_matrix#anchor_agent_collector_compatibility
Also you mentioned that you Java script agent 6.2 is not available, does 6.5 supports your app, if it supports then use the same.
Ravi
0 Likes 0 · ·
Hi Ravi..no it wont support 6.5 also I tried by installing 6.5 but many .issues came into picture so I removed and installed 6.2.
One more doubt please help me in this.its reg.web service performance dashboard.
How to get aggregate value of 2 or more measures
All my concern is on Webservices. For example: I have 2 webservices A & B. And for Webservice A there are calls A1 & A2, For webservice B, B1, B2 & B3 are the calls.
What I want is, Aggregate Response time of webservice A. For which I have created time measure for A1 & A2. But I want combined value of A1 & A2 together.
Same is required for B.
End of the day, I want to see overall of performance trend of Webservices A & B individually.
Please help me with this.
0 Likes 0 · ·
Hi Sangeetha,
Yes, I will help you on this. But, instead can you create this one as a new question so that, it won't divert or confuse the community members who are referring this thread.
Ravi
0 Likes 0 · ·
Yeah Ravi thank you so much:) Same question posted in forums as well please see that and do the need ful
0 Likes 0 · ·
https://answers.dynatrace.com/spaces/148/uem-open-q-a_2/questions/206917/how-to-get-aggregate-value-of-2-or-more-measures.html
please look into this link and please give me the solution if possible please provide me the screenshots
0 Likes 0 · ·
Hi Ravi,I am expecting your reply on this query..If you are aware of it Please answer it ASAP..this is an urgent requirement for my client
0 Likes 0 · ·
Hi Sangeetha,
Seems with the current AppMon version it's not possible what you are looking for, you can aggregate the Measures by combing two measure values in Text and Measurement dashlet for getting the real time data. But as you are looking for performance trend hope the measure which you are going to create newly by combining both will store data now on wards in PWH, it might not have the performance trend data.
0 Likes 0 · ·
Hi Ravi,Thanks for your Time.
If that is not possible then can you suggest me to meet the below client requirement.
week/15 days trend report on what all services are slow. We need a report on area which needs improvements, what all services behaving poorly and how much end customer facing slowness and because of what.
Can we able to generate this kind of reports from our tool if yes means
please guide me to do this?
0 Likes 0 · ·
